| Looking for some advice? -- installed AGX adjustables with Intrax springs on the front and rear of my ride. Is the center strut nut used to fine tune ride height (ie., loading on the spring)? Details: Car was driven and sat for a few days, with front tires at 33psi and rears at 36psi I measured the ride height. Took the reading from center tire, ground to fender lip. Fronts are about 3/4 of an inch higher than the rears? You can visually see the difference. Instead of threading the center nut all the way down -- if I leave just a few threads at the top is this the way to compensate for the front to back height differences?
